DISCUSSION => Electrical => Topic started by: bmwman91 on March 20, 2006, 11:51:48 AM
I recently finished my final sensor calibration tests. All I have to do now is load the conversion program onto my controller and finish wiring the electronics (the digital stuff). I really really hope to be testing by the end of the week. Not just for me, but my grade in Senior Project and graduation depend on it as well!
(http://www.e30tuner.com/other/maf001.jpg)
(http://www.e30tuner.com/other/maf002.jpg)
well, it will make a hell of a CPU cooler in any event...
looks great man... congrats!!
Lol. There's an idea...I can use it to clock the air inflow rate into my computer...
lookin good william, can't wait to see it on the car
Cool! Keep us updated!
why not MAP sensor?
I have a few questions just out of curiousity. My knowledge base in this area isn't deep so feel free to fill me in with the correct info.
I know a Mass Air Flow sensor converts the amount of air drawn into the engine into a voltage signal and the ECU needs this information so it knows injection duration, etc. I know a MAF im principle operates by using a thermister, power transistor, and a comparator.
I'll try to break all the questions into bite size chunks.
1) What does the car have in stock form? A Vane Air Flow Meter (potentiometer, return spring, etc)?
2) Both types output a voltage/air mass curve. How do you know what kind of curve the stock ECU is expecting?
3) If the curves don't compare nicely, how do you know you're not telling the engine to use too much or too little fuel? I'm assuming you have to rewrite the ECU's fuel curves?
4) If not rewriting the ECU's fuel curves, how are you converting the MAF's output voltage curve into one that the stock ECU can use?
5) If you are rewriting the ECU's fuel curves, are you using megasquirt?
6) If rewriting the fuel curves, how do you know what a good fuel curve for the M42 is? Is it a trial and error thing or is there an easy ratio that you always try to obtain?
7) What makes the MAF so much better than the stock sensor? Will it respond quicker?
8) What is that MAF from?
It looks like an interesting senior project. Nice work so far.
My senior project wasn't as practical. It was sponsered by a company who makes transducers and I used a bank of different frequency narrowband transducers to send out an ultrasonic signal and then monitored for a response. I then did an analytical cross correlation between the output signal and the received signal. With that and the speed of sound in the medium (which was air at this point), I could calculate the distance. If there was more time I would have added hardware that would allow it to calculate it's own sound of speed so it could be placed in any medium (water, air, thin air, dense air, space, etc) and it would accurately calculate distance. It used 4 pairs of transducers with the lower frequency ones calculating long distances and the higher ones doing short distances. The system would automatically pick the most optimum frequency transducer for the distance.
It was a good project overall and included a lot of electrical engineering aspects including signals, power electronics (transducers need to be fed hundreds of volt pulses), filter design, digital electronics (I had an FPGA doing system controlling, buffering data and having it accessible to a uP bus for a CPU), and software design.
Senior projects are fun when they're over :D
that was quite the mouthful.
sounds like you took on quite the interesting project.
to answere one fo your questions the benefits would be:
no flaper, or spring which means less restriction which means more flow, significantly better throttle response and a little more power.
i think he's trying to get ahold of the stock fuel maps so that he can remap the stock chip? i know hes atleast looking for the stock maps... i'm not really sure what hes gona do if he can't find them, or get them to workt ho.
as for figuring out fuel maps, for the best results you would have the car on a dyno and play arround with the maps, but i'm pretty sure there is an optimum A/F ration depending on combustion chamber shape, piston head, compression, and all that good stuff.
Actually, there is no chip reprogramming at all. This will be pure plug-n-play when it is done. I mapped the voltage output of each sensor at various flow rates and modeled them mathematically. I made an equivalence table & stuck it on a microcontroller. The DME will not need any work, and will think the AFM is still there. You just get all the MAF benefits on top of that.
and what is one of these units gona cost?
I will work out pricing once I have a fully working & reliable prototype, and I have worked out a deal with an electronics fabber to produce the circuits (I will have PCB's made & hopefully surface mount components). I would probably say in the $250 range. The sensor would NOT be included (it is a very easy part to get through Kragen's for like $50, or a wrecker for $20). I do not like the idea of shipping the sensor as it has breakable stuff in it, and it just adds to the cost of everything.
The other part that would cause a rise in price is adapters to make it fit. I am trying to keep it all as simple as possible, and fitting it to the stock air box is not an option, at least not a cost effective one. I just have to come up with a way to make it fit the air boot, and make a heat shield. We shall see. I have not really made too many plans for a mass produced product, but I guess if there is interest I could look more into it after the project is done. Unfortunately, this will not be the $100 magic MAF solution some people may be wanting...it does not exist. I will keep my progress posted though.
what kind of increases are you expecting with this conversion?
So if it is a plug and play solution then you must have hardware to map the MAF curve to the stock curve. The electronics part of the system sounds pretty basic then. Perhaps I can give some advice how to keep the cost of electronics down.
You can do this:
ADC -> FPGA/CPLD -> DAC
You'll also need votlage regulator(s) and an oscillator.
From what I can tell, you don't need the cost or complexity of an microprocessor. All you need is a lookup table to do the curve conversion.
I'd have to look into it, but the FPGA or CPLD is inexpensive and DAC and ADC are also cheap because this system runs slowly.
I've been involved in making many PCBs and most of the time http://www.pcbexpress.com is the cheapest... especially if you can let them take a week or two to build it. You just need to make sure that your PCB design file is correct because they just build it.
I've also done a lot of surface mount work... and it is easy enough for you to do at home provided you have several tools. You can buy a stencil that will allow you to scrape on solder paste onto all the pads on the PCB. Then you place the components on the solder paste covered pads. This is very easy but it can be a bitch for fine pitch chips. Still, I was able to do this for .5mm pitch CPLDs... and that's tiny. Then you can bake them in a toaster over. I've done this hundreds of times and it comes out great and it's much cheaper than having someone do it for you.
It may be too late in your senior project process, but I'd be happy to give some electronics advice. At a minimum the advice above can help you reduce the cost and complexity of the electronics. PM me about it if you'd prefer to keep your "special sauce" secret. :D
you guys have some awesome synergy brewing... dare I say on the order of:
(http://ee1394.com/bmw/m42club/misc/spock_kirk_bmw.jpg)
LOL!!!
Thanks for the advice Zoso. I am looking into the FPGA/CPLD idea. I definitely agree, a microcontroller is way overkill. I had been hoping all that time that there was some sort of programmable lookup-table device, but being a mechanical engineer I have very limited electrical experince (at least class-wise). And that is good to know about the surface mount bits. Yup, I was using an ADC for the input and shot the digital output back through a DAC to the DME.
Sorry for the PM-novel... I hope some of it was helpful. It's difficult to describe to someone who doesn't do digital design or programmable logic design where to start and as I said, it may be better to stick with the microcontroller for the senior project grade and then get the CPLD going for a product.
If you want to look into it more, Xilinx sells development kits that have the CPLD (or FPGA) already mouted on a board and headers for programming, a programming cable, and the software to do everything you need.
http://www.xilinx.com/xlnx/xebiz/designResources/ip_product_details.jsp?iLanguageID=1&key=DO-CPLD-DK&BV_UseBVCookie=yes&BV_SessionID=@@@@0981986276.1143233446@@@@&BV_EngineID=ccckaddhgehflficefeceihdffhdfkf.0
english? :D
I have no idea what you two are talking about - but sounds like it's a start to a very good thing for the 318is owners.
dang I don't really know whats going on anymore lol
i'm a little lost too... i guess thats what iget for choosing business instead of engineering. however engineering seems really fun... major switch?:D
Reading all that made me regret dropping out of college that much more...lol
yeah I'm in for business also :D
Hehe, well it looks like folks of all majors can appreciate a good car...as well as a good MAF conversion :p
haha you create it, we sell it :)
my thoughts exactly:)
This is also known as:
The engineers do all the work and the business majors find a way to get a cut :D
I always thought it was " the business majors find a way to rip the engineers off" :D
Well shit, I see why people do not like to prototype with uC's. When you fry one it can be costly, at least when using one that's waaay overkill, as in my case. There is a $50 mistake I just learned from!
The hell with it. I am just gonna get a E/EEPROM memory chip, burn the data into it, and just take inputs & spit out my 'tuned' outputs. That way if I mess up it costs me like $3. Son of a bitch, I was trying to save $$$ for my next car insurance bill! If only I had realized how overcomplicated I was making this sooner!
Are you planning on ditching the microcontroller and going with only EEPROM? What EEPROM?
If you want, I can review your design. I can give you tips on how to make it more reliable, cheaper, easier, less prome to burning.
I already see the possibilities - Xilinx XCS05XL FPGA - has enough RAM inside it to do the look up table. $8.92 through digikey. You can reprogram it thousands of times.
yeah... what he said... gosh...:confused:
yeah I think I am going to say w/ business, to think I considered engineering!!
My father has a bunch of memory modules back home, I am gonna go mess with them there on my way to buy more parallel ADC's. I should onyl have to program it once as I have all the equivalence tables worked out. Granted, the WBO2 will have the final say, but the simple EPROMS he has will work for the moment.
Basically, all i need is 256 bytes of space, and to operate at 50Hz lol. Now, I will run at more like 50kHz because I can, but it is a simple application. Nobody rip off my idea or i will eat your first born!
Aren't electronics FUN?
An Atmel AT28BV64 (<$3) is also a very easy way to do this project. You just need a programmer to stuff the data from the PC.
You guys are way beyond my navy electronics training here, I'm with all the other Liberal arts/business majors on this one. Hopefully this works out well enough to get you a good grade. If not, the rest of us can vouch for the effort that's obviously gone into this!
Brian
OK, BIG UPDATE.
I got the prototype circuit working. Zoso, I used a M27C256B-15F1 EPROM to store the values, put it in Read/Output mode, and hooked the ADC right to the Address pins. Waaay simpler & faster than the BS2, and its only $3.11. I am going to hook up both sensors to my 'flow bench' this weekend to verify that the outputs are what they need to be, then test it on the 318. I was getting really pissed off yesterday. I thought the ADC/DAC/both had died or something. Turns out I had the 150pF capacitor on the wrong pin fo rthe ADC timing circuit lol. There were 2 pins, and I had it backwards (friggin ckt diagrams are such a PITA to follow sometimes).
Yay, looks like the M42 will get a MAF real soon!
OK, BIG UPDATE.
Bomb diggity!
G-luck with it.
OK, BIG UPDATE.
thats pretty much all I understood but I guess thats the good part :rolleyes:
wahoO! i look forward to the trial run.
Nice work man!
Out of curiousity, what type of programmer did you use? Do you have a UV light?
BTW, those chips sell for $1.53 on digikey :D
Yeah, got a UV eraser & ISA-port-based programmer on a 66mHz Cyrix 80486 back home lol. I guess keeping it was a good idea afterall. The prices ranged from $1.53 to whatever...the one I use was like $3 on DK. They were 'free'...we already had them laying around from like 1993 lol.
hey can you test the air/ fuel with some 19lbs injectors? cause I think thats what most all with upgraded injectors have!
i have an Atari console at home if you need it for parts. I believe it was a X-mas present in 1983.
Lol!
Well, all I am waiting on now is my project partner to finish working on the fitment of the MAF. It will be fittable to the stock air box, as that is the easiest way, and a heck of a lot cheaper than trying to make a support bracket & heat shield, AND buy a conical filter. Honestly, from my experience, the best performance comes from the stock air box anyway. The open element filter I ran on the last car just let more noise out.
that's awesome man, we're all rooting for you!
its like porn for the car
very stimulating indeed.
One Simple Question for you MAF wizards- Is the m44 MAF of any advantage for a project like this?
The reason the Mustang MAF is being used is its abundance, and low cost. The M44 one is pricey depending on if you can get it, AND it may give a digital output rather than analog, which would just be more work for me. If someone can get me one I might be willing to run some tests, but for now the Mustang one is the way to go. Also, the MAF's output is logarithmic, and is more accurate at lower flows. The M42 will stay in the Mustang MAF's 'lower' output portion, giving it a slight increase in accuracy.
sounds like a great project. Also if you are looking for cheap PCBs check out http://www.ezpcb.com They are based out of China and it keeps the costs really low. I have ordered from them twice and they are really quick and the quality is great. I just ordered 50 80mm x 60mm boards and they came to about $3.60 a board shipped.
Jake
is it in yet!? :P
mine is sitting in my room too ....
