DISCUSSION => Engine management => Topic started by: Damon in STL on May 27, 2012, 04:12:34 PM
Hi,
Does anyone have a base .msq file using EDIS4 they could share? I've got my base code from my s14 usint a 30-1 wheel....and I've not figured out how to change it to the 60-2 wheel.
TIA
Damon in STL
p.s. Once I get the base engine running I am going to install my turbo components.....so, a base turbo code would also be helpful! Thanks!
Hi,
TIA
Damon in STL
Looks like my EDIS system which I had running my s14 is not a plug and play on the M42. EDIS must have the 30-1 trigger wheel and the stock 60-2 will not drive EDIS4.
Oh well.....back to soldering....
Still would appreciate a base .msq
Damon in STL
Looks like this is the path to take.....
http://www.diyautotune.com/catalog/quadspark-four-channel-ignition-module-p-481.html (http://www.diyautotune.com/catalog/quadspark-four-channel-ignition-module-p-481.html)
Damon in STL
Got the engine running this weekend on MS2 v3. Added a second ignitor and used the coil pack from the EDIS4 in wasted spark mode. The ignition and fuel code I'm currently using is from my s14 code. Still looking for a good M42/M44 base code.
Damon in STL
