DISCUSSION => Engine + Driveline => Topic started by: ClayW on May 21, 2012, 10:16:58 PM
Should I use RTV on intake manifold gaskets? If so, which kind?
no
no
What about this stuff?
Permatex 80065
(http://ecx.images-amazon.com/images/I/418VWMNGWCL._SL500_AA300_.jpg) (http://www.amazon.com/Permatex-80065-A-Gasket-Adhesive-Sealant/dp/B000HBICK2)
From what I've just read across other forums, it is not recommended to use rtv on the intake manifold gaskets. Take a razorblade and scrape the metal surfaces clean and smooth and then apply the paper gasket to have a seal free of vac leaks.
No sealant is required, either.
+1
No-no on intake.
