DISCUSSION => General Topics => Topic started by: G-Man on November 15, 2006, 11:44:59 PM
The odometer broke on my 86 325e (263K) but speedo works fine. In my parts bin, I have a complete instrument cluster from my 91 318i (M42) parts car. Of course the tach will be way off by swapping instrument clusters from an eta M20 to a M42.
What's the easiest fix, swapping out the tach in my 91 instrument cluster or swapping out the speedo in the 86 instrument cluster? I guess it doesn't really make that much difference. I've never taken a E30 instrument cluster apart before, any been there, done that recommendations before I start?
G-Man
91 318i sedan
91 318i (parted out)
74 2002 tii
73 Bavaria
70 2800
96 4Runner (parts hauler)
You'll need to swap out the odometer gear most likely. These tend to fail most of the time when the odometer goes out.
If you have a spare working odo... you can actually turn the numbered mileage dials VERY carefully with a small screwdriver... (obviously, I hope you're rolling them forward and not back!)
the eurodepot will prolly do an exchange plus a bit of $ and they can set the odo to whatever mileage you want; Joel's a decent man.
finally, expensive but a real fix: http://odometergears.com/
