DISCUSSION => Engine + Driveline => Topic started by: willworkfore30s on April 03, 2012, 04:49:01 PM
Title: Cutting out and oil leak.
Post by: willworkfore30s on April 03, 2012, 04:49:01 PM
I posted a couple weeks back about how my m42 would cut out after start up until I hit higher RPM's and then it would be good.
Well after it doing that for about a week, I noticed an oil leak.  Its not pouring out but I wouldn't call it a small one.  The internet suggested it was the oil canister gasket.
At the same time I noticed the oil leak, the cutting out got worse.  It happened over night.  I got in the car to drive to school and got half way and the car started cutting out much worse.  It didn't seem to matter the RPM's.  I took it back home and parked it for the weekend.
I just took it for a test drive and it did fine getting out of the neighborhood under light throttle.  But as soon as I got on the road with some heavier throttle it started cutting out and had no power.  I turned into a parking lot to turn around.  It died when I let it hit idle.  I started it back and kept the revs up.  Drove it back home and it did ok but was still down on power.  I parked it in the drive and left it running.  It seemed to idle ok.
I am wondering if the oil leak is related or just a coincidence and if anyone has any ideas on the cutting out issues.
I should have some more info on where the oil leak seems to be coming from later tonight.
Post by: n2motorsports on April 03, 2012, 05:16:38 PM
did your oil pressure light come on?
Post by: DesktopDave on April 03, 2012, 07:56:22 PM
Usually that o-ring fails behind the filter housing, but the paper gasket is also a likely leak.  I'd suspect it's not related, they all do that.
Post by: willworkfore30s on April 03, 2012, 08:18:43 PM
My oil pressure light never came on.
Any ideas on the cutting out?  I did recently do the mess under the intake, could that be a vacuum leak or a back ICV?  I believe I have an old ICV laying around.
Post by: DesktopDave on April 03, 2012, 09:15:25 PM
Did we do the coolant temp sensors?  I can't recall where we were at on your case.
Post by: willworkfore30s on April 03, 2012, 09:41:58 PM
We figured out that the coolant temp sensor had an issue.  I will repair the wire while I am working on the car this time and that should fix that.
The way I did the mess under the intake was to block off the port on the side of the block and the top of the plastic tube.  I don't guess this would cause any issues as I read a lot of people saying it worked fine that way for them.  I haven't noticed a coolant leak.
Post by: willworkfore30s on April 04, 2012, 11:00:16 AM
I did some digging around in the engine bay this morning before I left for class.  The short hose going from the ICV to the intake is the only one that wasn't replaced when I did the mess under the intake so I suspected it to be the culprit if it is a vacuum leak.  When I check it out, I noticed that the hose coming out of the other end of the ICV, which I have running to the intake elbow, was at a pretty harsh angle.  It didn't seem to completely kinked but I could see it getting that way as vacuum is pulled.
I will sort that out and see where it gets me when I get the car back on its wheels.  I am fixing some brake issues while its in the garage.
As for the oil leak, I haven't gotten around to finding it yet but the whole underside of the pan seems to be covered in a thin layer of oil.
I am not sure that this will fix my issues so I am still open to ideas if anyone comes up with any.
