DISCUSSION => Engine + Driveline => Topic started by: 318bud on March 22, 2012, 07:31:45 AM
Title: Stalling at startup(video)
Post by: 318bud on March 22, 2012, 07:31:45 AM
My car has always done this.
I have an e36 and some days is worse than others. It wont stall if im giving it gas, but when i stop revving it will stall(in video).
Its fine once i start driving and revving it up, but will sometimes randomly stall at a light
It was pretty bad today, so i decided to make a video and ask you guys
I already replaced MAF and boot
Going to try fuel injector cleaner
seafoam?
o2 or crank sensor?
what do you guys think?
(http://i61.photobucket.com/albums/h42/seaPPPP/th_stall.jpg) (http://s61.photobucket.com/albums/h42/seaPPPP/?action=view¤t=stall.mp4)
Post by: Geoff on March 22, 2012, 08:00:45 AM
I'd find out what codes its throwing, for starters.    mechanically speaking,  when was the last time the fuel filter was changed?
        Geoff
Post by: 318bud on March 22, 2012, 08:09:47 AM
stomp test says no codes
shop hooked up scanner and told me same thing
fuel filter and pump were changed about 2 years ago
Post by: colin86325 on March 22, 2012, 10:21:18 AM
Sounds like a vaccum leak in a hose or the intake manifold gasket.
Post by: 318bud on March 22, 2012, 11:47:25 AM
the hoses all look fine. Havnt thought of intake manifold gasket. Im gonna check that out
Post by: ose30 on March 23, 2012, 01:27:09 AM
Vacuum leak or bad fuel pressure regulator.
Post by: 5m1dy on March 23, 2012, 09:25:30 AM
Check the two pipes on the Idle Air Control Valve. Mine's been known to pop off, which would cause something like this to happen, where it can run for a bit, then dies etc. Its just under the intake pipes, near the firewall. If the pipe disconnects, it won't throw a code , as the resistance/functioning of the unit itself still works.
Post by: willworkfore30s on March 23, 2012, 03:44:19 PM
My e30 has almost identical symptoms.  I just recently did the mess under the intake and I don't remember it doing it before that but I didn't drive it very much before that either so IDK but I will look into the vacuum leak thing.
