DISCUSSION => General Topics => Topic started by: lqbanotxano on February 28, 2012, 09:29:02 AM
Title: Exxon Valdez & sleeping dogs laying
Post by: lqbanotxano on February 28, 2012, 09:29:02 AM
Sunday, I replaced my vacuum reservoir tank & flushed my power steering system. I also removed the reservoir from the bracket. I was trying to take it off so that the reservoir & filter could be flushed. I gave up as it was getting dark & was not able to remove the hoses from the reservoir. I just managed to replace (1) of the clamps only ( hate factory BMW clamps).
After fixing my vacuum reservoirs, now I have this chirping sound. Monday I called the stealer looking for a DISA valve, thinking that is what it was. The parts man said my car does not have a DISA. My M42 intake does not look like the E30 M42 intake. I thought it had a DISA. Does my car have a dual resonance intake or not?
After flushing my Power steering system, it is leaking…causing a small puddle under the car. I wonder if I cracked the tank or disturbed something (something about leaving sleeping dogs alone). I used Dexron 6 ATF, a synthetic blend. Maybe I should have stuck to straight Dexron 3 ATF.  Further investigation needed.
Post by: DesktopDave on February 28, 2012, 04:34:13 PM
Hrm.  Lots of stuff going  on there.  I thought all the curly manifolds were DISA?  I'm not sure though.
I couldn't get my P/S to stop leaking either.  I pulled the whole thing out of sheer frustration.  I usually slice a bit off any hose I pull..makes the clamp grab another section of undisturbed hose.  I just use a sharp utility knife.
