DISCUSSION => Suspension => Topic started by: FL318is on November 01, 2006, 02:44:09 PM
Title: Offset question.
Post by: FL318is on November 01, 2006, 02:44:09 PM
Found a set of 16x7, 38mm offset including 10mm hubcentric spacers, 4x100.
Will this fit on our 318is?
Post by: RED E30 on November 01, 2006, 02:52:22 PM
With ET28 the clearance issues will depend on the design of the wheel.  Some wheels would clear some may not.  A trial fit may be the only way to be 100% certain of knowing.
Post by: 2002maniac on November 01, 2006, 05:28:54 PM
I'd be willing to bet they would work fine.
if you used 15mm spacers I would guarantee perfect fitment.
Title: Thx
Post by: FL318is on November 02, 2006, 07:41:57 AM
Always a challenge when doing math in the head! :p
Post by: Alpine003 on November 02, 2006, 11:07:51 AM
Generally a 6" width can be up to 35mm while 7" can be up to 25mm to clear the strut housings. So 38-10=28mm would be close and I'm sure would depend on the amount of contact patch and size of the tires as well as your camber settings.
Title: This is the rim.
Post by: FL318is on November 02, 2006, 12:37:17 PM
Of course I would be getting the 4x100.
Title: OTAY then!
Post by: FL318is on November 02, 2006, 12:39:55 PM
Quote from: Alpine003;13197
So what 2002maniac said, "I'd be willing to bet they would work fine. if you used 15mm spacers I would guarantee perfect fitment." . would be the way to go!  Go from a 10mm to a 15mm spacer.
Post by: Choking Hazard on November 07, 2006, 09:03:03 AM
Man those are purty.  Got some nice callipers & rotors to put behind 'em?
Post by: M42boy on November 09, 2006, 12:33:47 PM
Quote from: 2002maniac;13134
If you go with spacers, please remember to use longer wheel bolts!  :rolleyes:
Post by: Alpine003 on November 09, 2006, 12:59:32 PM
Quote from: M42boy;13556
I've had good experience with Vorshlag. Their prices are pretty good for wheel stud kits too. http://www.vorshlag.com/wheelstuds.php
Post by: 2002maniac on November 10, 2006, 03:38:32 PM
Quote from: Alpine003;13557
Yup. I have their studs as well.
Order a few extra studs and nuts and ALWAYS put anti-sieze on them.  I slacked and ended up with two galled studs :(
Post by: n2motorsports on June 13, 2007, 01:17:14 PM
rims are 15x6.5 offset 34mm
Will they clear strut side with aftermarket strut/spring.
thanks.
Post by: Vladi on June 13, 2007, 04:27:21 PM
Yes.
