DISCUSSION => Engine management => Topic started by: 91 e30m42 on August 23, 2011, 04:39:38 PM
yes im due for a smog check in California its the 2nd yrs since the last one (renew Reg.) ... last time it passed with flying colors with all the mods( plug wires,carbon intake and k&n filter, and exhaust) except for the chip was stock ... my question is will it pass with my Mark D 91 octane chip or would i have to put it back to stock chip
I dont see why the chip would make much difference. Its generally just ignition advance and shouldn't be a problem in the tested areas.
Any penalty for trying and failing? If not I would just give it a try.
I don't know how CA tests emissions but it is pretty strict here in Seattle and I passed with a decent amount of mods, mark d chip, and about 2/3 of the emission equipment removed. Wasn't even close to failing in any category.
s far as i know we are the strictest smog state i have a friend that was all stock 2005 bmw and couldnt pass smog... i passed because i had a brand new rebuilt motor with every line and hose replaced,old parts to new including drive train the only old thing is my icv which i think is going bad but i was gonna do it and see but i just wanted some others input on if it can pass or not... thanks Nick for your input
I assume you finished the SMOG test by now. Basically, as long as you do not have huge vacuum leaks, your O2 sensor is functioning properly and there's a marginally functional catalytic converter installed, you should pass.
I had failed once in the past, but I had vacuum leaks, an improperly installed wide-band O2 sensor and a mostly dead catalytic converter (from the first 2 items pushing raw gas into it). A new cat, even with the other problems, made me pass with flying colors (and then the cat was dead again in 2 years...bit I fixed everything before replacing it).
if you're that worried, why not just put the stock chip back in test it then put it back
i would if i could but i dont know how the stock chip would react with my MM motor... wither way im going today to get it smogged if i fail i get a free retest anyways so it wouldnt hurt
You should be fine with the chip. The only maps that really get adjusted are the full-throttle ones. In closed-loop operation, with a working O2 sensor, you are fine.
thanks bmwman im sure it will pass the motor has low miles on it and every hose is brand new, and so is every sensor just a modified chip is concern but hey trial and error right and theres always the state referee... i have an appointment today after work so ill seee how it goes
car passes no problem he did say i may need to change my cat soon any suggestions
