PAPER OR PLASTIC => WTB/WTT => Topic started by: jdirty on August 18, 2011, 12:48:00 PM
my head took a shit, so i need an e30 m42 head for my 1991 318is.
no funds for a swap right now, but got funds for a head.
head with decent valves if possible..
miles?
shipped to 89121?
thanks.
edit:
found one over at r3v already machined. everything included except cams. :)
I recently bought a 318is as a shell, but the engine and everything is still in it. The main bearings are rattling around in there when it turns over so I assume the head is just fine. It seemed to be good when it cranked over. I was gonna just swap the main bearings and run it until it quite then swap it but I found a cheap m42 with less miles that I am going to use.
Anyway, odometer stopped in 08 at 145k. I had some records from a shop that showed it getting routine maintenance in 2010 so I would assume that it has somewhere around 200k on it.
Make me an offer on any parts you would be interested in from the motor.
Where are you located?
Raleigh NC
