PAPER OR PLASTIC => For Sale => Topic started by: dude8383 on August 02, 2011, 10:59:16 PM
Hey guys,
I was cleaning out my garage space and found some spare M42/M44 stuff
Used:
M42 Connecting Rods - $50 shipped
(https://lh5.googleusercontent.com/-DStg5D-AyZ4/TjtgNozDtzI/AAAAAAAADzc/zK2vir3FA78/s800/M44%252520Rod%2525204a.jpg)
(https://lh5.googleusercontent.com/-pu_iL8REZSE/TjtgNOSZgeI/AAAAAAAADzc/u2rT4Zex_fw/s800/M44%252520Rod%2525204.jpg)
(https://lh4.googleusercontent.com/-fFbeylhMvrA/TjtgNBg0bJI/AAAAAAAADzc/Au2wacMrzZo/s800/M44%252520Rod%2525203a.jpg)
(https://lh3.googleusercontent.com/-UYdNRN0SHjo/TjtgMkNxObI/AAAAAAAADzc/HyoNb9Z3S3w/s800/M44%252520Rod%2525203.jpg)
(https://lh5.googleusercontent.com/-HGS6af6Ar3I/TjtgMv0XQPI/AAAAAAAADzc/JnMhSnoZ8zs/s800/M44%252520Rod%2525202a.jpg)
(https://lh6.googleusercontent.com/-VYF3vS8Oy5U/TjtgMSRVcaI/AAAAAAAADzc/73FFYOCpkQI/s800/M44%252520Rod%2525202.jpg)
(https://lh3.googleusercontent.com/-O55FXvzo154/TjtgL65MSVI/AAAAAAAADzc/JCroGm-4f-g/s800/M44%252520Rod%2525201a.jpg)
(https://lh6.googleusercontent.com/-9gR1wi0XZeo/TjtgL5AHC-I/AAAAAAAADzc/FXrxtH7mXJQ/s800/M44%252520Rod%2525201.jpg)
Rod bearings have not been removed because I didn't want the mating surface to become damaged... thats why the bearings are all scuffed up.
M44 Cams - $75 shipped
(https://lh3.googleusercontent.com/-ql1vssQtd2M/TjtgRrHlfvI/AAAAAAAADzc/COUEd1lLOrM/s800/M44%252520Cams%252520Detail.jpg)
(https://lh4.googleusercontent.com/-qjM-_Qx9y4M/TjtgR4c5VVI/AAAAAAAADzc/ecgGrgveQuA/s800/M44%252520Cams.jpg)
M44 Valve Cover - $75 shipped
M42 Alternator - $30 shipped
T-stat Housing - $15 shipped
Lower Timing Case cover with Main seal - $25 shipped
(https://lh6.googleusercontent.com/-kXggtWZw5A4/TjtgRNq628I/AAAAAAAADzc/9_ZaPOIY9dQ/s800/M42%252520Lower%252520Timing%252520Cover.jpg)
Slightly used (approx 3k):
P/N 11311721419 - M42 lower timing guide rail - $25 shipped
P/N 11311247470 - M42 timing chain guide rail - $25 shipped
NEW ITEMS:
P/N 11141721919 - Upper timing case gasket set - might be missing t-stat gasket will check... $5 shipped
P/N 11141247837 - Profile Gasket $5 shipped
Front 21mm non-adjustable ST Sway Bar - comes with all of the necessary hardware to mount. $140 shipped
(https://lh4.googleusercontent.com/-Za0z0sRIkSs/TecV43KZ1aI/AAAAAAAAC7M/78dO1LVgH8M/s800/IMG_20110531_194514.jpg)
PM me or email me directly...email is preferred!
d DOT oreshkin AT gmail DOT com
Email sent.
replied
bump
mhw's are sold!
lollipops sold
to the top again
bilstein sport shocks/struts added.
off topic free bump-
what is your suspension set up in your sig pic? Those are 15" weaves right? Car looks good!
bump up.
still have a few items gents.
http://forums.bimmerforums.com/forum/showthread.php?t=1695490 - i have a few 24v parts if anyone is interested...
bump
bump mocal oil cooler sold
up
bump added some pics
and up again!
