DISCUSSION => Interior => Topic started by: monty23psk on July 11, 2011, 10:43:40 PM
Title: HVAC illumiation of front window defog diagram
Post by: monty23psk on July 11, 2011, 10:43:40 PM
Hey guys,
I wonder if this is normal even though I dont think so. My little diagram for the front window defog under the AC switch has always had a top gap that looks like the diagram slide down. About 1-2mm in thickness. Is this normal? I have never looked at another e30 at night to see. I am swapping out my burnt out bulbs with LED and would like to know if this is normal as now with the LEDs the hole is even more noticeable. It might be a sticker but can't find it in OEM. I will eventually find out while I remove it when I am replacing the  bulbs. The LEDs brighten that area up nicely. Only able to do right side as you can get to bulb from underneath. But if someone knows, mabye I can the parts before hand so I can take care of it while I am doing it.
TIA
