DISCUSSION => Engine management => Topic started by: naika on June 09, 2011, 10:28:17 AM
HI Guys
I just bought a Touring 318i swapped with an M42 in France, and I'm considering the Ethanol conversion as it is about half the price of regular gas over here.
Has anyone done this?
I assume I need a chip to modify ignition timing and injector timing as well, but do I absolutely need to change injectors to make up for the additional flow, or increase the pressure in the injecto ramp?
Any info would be useful
Thanks
(http://i209.photobucket.com/albums/bb173/franckleprodhomme/Touring%20M42/dsc00911.jpg)
(http://i209.photobucket.com/albums/bb173/franckleprodhomme/Touring%20M42/dsc00910.jpg)
(http://i209.photobucket.com/albums/bb173/franckleprodhomme/Touring%20M42/dsc00415.jpg)
(http://i209.photobucket.com/albums/bb173/franckleprodhomme/Touring%20M42/dsc00414.jpg)
Running e85 on stock injectors with higher fuel pressure. (because inspection)
would recommend bigger injectors..
So, I would need to instal something like 240-250cc injectors and a new map for the ECU?
I have no idea about the alcohol (though I'd get that chip to advance timing aggressively).
I just wanted to say that I love those touring wagons. One of these days I'll be heading over & shipping one back. US DOT has a 25 year exemption that I'm planning on taking advantage of.
You need 30-40% more fuel when running on e85.
Car will work without new map :)
Imho best way is to buy bigger injectors from turbo car (SAAB 4 cil turbo engine, as I remember they are about 350cc and same size, or audi 5 cil turbo 300cc). Fine tuning could be done with fuel pressure.
Thanks Guys for your input
If I'm not mistaken, the 318is injectors are around 200cc, correct?
So if I would need to get 270-280cc injectors.
Being in France, I'll have to check what cars have those type of injectors.
@Bl0mgren: Can you please elaborate on the fact that I don't need a new mapping? I thought I'd need to modify the ignition a bit
Car will start and you can drive it. If you want engine to run fine and gain hp with good fuel consumption you should consider a remapp of course :)
