DISCUSSION => Engine + Driveline => Topic started by: spike318is on May 26, 2011, 08:42:47 PM
Title: flywheel and gearbox
Post by: spike318is on May 26, 2011, 08:42:47 PM
i'm changing gearbox from standard m42 e30 to m42 e36 box, i'm thinking of changing flywheel at the same time. will the m20 fly wheel work with this set up? also will the m44 box work the same?
many thanks
Post by: MikeDE on May 27, 2011, 02:30:48 AM
Don't bother changing your 'box, no point to it unless yours is fried and you have an E36'er lying around.
The M20 FW swap is well documented, search.
Post by: romkasponka on May 27, 2011, 03:43:55 AM
Quote from: MikeDE;104098
what do you mean, they have diferent gear ratios and there is a big point because of that?
Post by: spike318is on May 27, 2011, 12:45:18 PM
my current box is busted, a bearing inside i think.
