DISCUSSION => General Topics => Topic started by: eric16v on May 07, 2011, 04:26:44 PM
Title: disable ignition
Post by: eric16v on May 07, 2011, 04:26:44 PM
so I'm in the process of installing some mustang injectors. Got all the way put back together and noticed a leak I believe between injector 3 or 4. I couldn't really tell. So i'm wondering if there is away to disable the ignition with out cutting power to the pump so i can crank the engine and fuel pump with the rail in place and hopefully find the leak.
Post by: eric16v on May 07, 2011, 06:41:59 PM
anybody?
Post by: DesktopDave on May 07, 2011, 07:58:47 PM
Jump the fuel pump from the battery?
Post by: eric16v on May 07, 2011, 09:01:30 PM
ok will try .
thanks
Post by: RED IS 91 on May 08, 2011, 05:03:11 AM
Pull the spark plug wires off and crank the engine over.
