DISCUSSION => Engine + Driveline => Topic started by: ClayW on April 03, 2011, 09:45:43 AM
Title: What hose goes here?
Post by: ClayW on April 03, 2011, 09:45:43 AM
I have a spare vacuum port on the throttle body after I cleaned up the mess under the intake, thanks to this thread (http://www.m42club.com/forums/showthread.php?t=2742).
(http://i119.photobucket.com/albums/o143/clayweiland/HPIM2372.jpg)
So, what should I put here? Plug it, maybe?
Otherwise, does anyone see anything amiss so far?
(http://i119.photobucket.com/albums/o143/clayweiland/HPIM2368.jpg)
Post by: DesktopDave on April 03, 2011, 10:12:59 AM
I think that one goes to the vacuum canister.
Post by: a930rocket on April 03, 2011, 10:16:28 PM
+1
Post by: ClayW on April 03, 2011, 10:30:36 PM
Quote from: DesktopDave;102788
What vacuum canister? Is it necessary?
Forgive me; I'm new to the M42 world and I didn't remove this engine from its donor car.
Post by: DesktopDave on April 03, 2011, 10:46:34 PM
There's a purge valve and a vac can under the P/S reservoir on the stock car.  If you don't have a vapor recovery system off the gas tank you have little need for it.  I'd plug it if that's the case.
Post by: ClayW on April 04, 2011, 07:36:01 AM
Perfect. Thanks!
Post by: a930rocket on April 04, 2011, 11:32:53 AM
Here's a pix of the canister. It has a short piece of hose (with a one way valve I'm guessing) and then runs to the TB.
(http://i1143.photobucket.com/albums/n632/a930rocket/DSC02094800x600.jpg)
Post by: aworthybrother on April 04, 2011, 03:47:24 PM
Here's a btter illustration...
(http://i361.photobucket.com/albums/oo57/rjcaptsbmws/Photo0294.jpg)
Post by: ClayW on April 14, 2011, 08:17:50 AM
Holy Throttle Body buildup, Batman!
Thanks, fellas.
