PAPER OR PLASTIC => For Sale => Topic started by: Drewdown on March 18, 2011, 04:48:01 AM
Hey guys, I have some parts left over from a blown engine out of a 91 318is. Im kind of a noob when it comes to m42s so try and work with me as best as possible. Prices are going to be a rough estimate based on what other people sell for... if Im way off base just let me know. Also everything is OBO :D
Parts are located in the Bay Area, California
Oil Filter Housing - Make me an offer
(http://farm6.static.flickr.com/5211/5475145038_5dc88ef10d.jpg)
Headers - Best offer on this one too
(http://farm6.static.flickr.com/5173/5475144742_71df1b74ce.jpg)
Lower Intake with Injectors and Fuel Rail sold
Throttle Body -sold
Upper Intake Manifold sold
AC Compressor - 30 The outside of the pulley is dinged up as you see in the pic... shouldnt effect it though :dunno:
(http://farm6.static.flickr.com/5175/5475143000_642a53ba92.jpg) (http://www.flickr.com/photos/57910654@N04/5475143000/)
DSC_0923.jpg (http://www.flickr.com/photos/57910654@N04/5475143000/) by Drewdown49 (http://www.flickr.com/people/57910654@N04/), on Flickr
(http://farm6.static.flickr.com/5212/5474546127_411330e54e.jpg) (http://www.flickr.com/photos/57910654@N04/5474546127/)
DSC_0924.jpg (http://www.flickr.com/photos/57910654@N04/5474546127/) by Drewdown49 (http://www.flickr.com/people/57910654@N04/), on Flickr
Power Steering Pump - 25
(http://farm6.static.flickr.com/5092/5475142518_fea00a1790.jpg) (http://www.flickr.com/photos/57910654@N04/5475142518/)
DSC_0927.jpg (http://www.flickr.com/photos/57910654@N04/5475142518/) by Drewdown49 (http://www.flickr.com/people/57910654@N04/), on Flickr
Alternator -sold
Throttle Body Heaters - Dunno if anyone actually keeps these so 2 bucks for the one without a lower part and 4 for the full one
(http://farm6.static.flickr.com/5253/5475140912_9e60cc6095.jpg)
(http://farm6.static.flickr.com/5298/5474812452_cf8785c023.jpg)
Crank Pulley - 10
(http://farm6.static.flickr.com/5014/5474215605_7675f90203.jpg)
Harmonic Balancer - 10
(http://farm6.static.flickr.com/5020/5474811602_6ff741ac23.jpg)
ICV - Sold
Thermostat Housing - 7
(http://farm6.static.flickr.com/5013/5474214173_2b4b3cf6c5.jpg)
Valve Cover - Sold
Coil Wiring - 15
(http://farm6.static.flickr.com/5219/5474809868_64c6318f27.jpg)
Tranny Plate thing (Sorry I forget the name) - 5
(http://farm6.static.flickr.com/5174/5475142220_c564436c81.jpg)
Cam and Crank Timing sensors - 10 each
I still have basically the whole bottom end. The block and the crank are gone but I might be able to salvage other parts.
Upper and Lower Timing Case Covers - 15 each
(http://farm6.static.flickr.com/5058/5475141878_94a5d99431.jpg)
Crank Pulley - 10
ICV - 10
(http://farm6.static.flickr.com/5058/5474811312_e7c2f2ccc5.jpg)
Valve Cover - 25
(http://farm6.static.flickr.com/5252/5474213831_2698b4f990.jpg)
Coil Wiring - 15
Okay so now comes the tricky part... I Have a whole head assembly from the engine that blew. The cams are in good shape and none of the valves appear to be bent. Sorry I cant describe the condition of this thing very well, but I can take a lot of pictures, so just ask :rofl: The piston on cylinder 2 went out, so the head got a small nick as you can see here in the upper right corner:
(http://farm6.static.flickr.com/5137/5538039090_7ea6f0519f.jpg)
Overall pics
(http://farm6.static.flickr.com/5291/5538038898_073cffd470.jpg)
(http://farm6.static.flickr.com/5211/5538039314_0055b84657.jpg)
Cams
(http://farm6.static.flickr.com/5212/5474547569_6431c16f7a.jpg)
The head can either be sold complete with cams and everything or parted out.
One last thing not pictured sorry
Prices are flexible... and if there's anything I didnt list that you might need form an engine just ask... I might have it.
I realize this is an old post, but wondering if you still have the a/c compressor and power steering pump? Would you take $25 a peice for them?
hnilsen@canalbarge.com
bump
I approved your 2nd post so you can merge or delete it. I must have missed it the first time.
Please write to Artem dot Lepilov at gmail dot com, I need a few pieces you got. Specifically, the throttle body pieces and maybe the ICV.
Thanks!
Any chance you have the front exhaust support bracket parts (the stuff that bolts to the bottom of the tranny & holds the downpipe)?
do you have an upper oil pan? thanks
How well does the a/c compressor work?
Still have the Thermostat housing? Compressor?
still have the exhaust manifold? and where are you located?
Are the cam gears, crank gear, and lower guide in good shape? If so I'll take them!
is that a denso compressor?? if so i take it.
PM sent
