DISCUSSION => Exterior => Topic started by: Euro Nation on September 22, 2006, 05:23:13 PM
Everyone calls me weird for finding the stuff to make this possible, but I like it. And they can't steal a CD player if I don't have one.
(http://www.euronationmotorsport.com/misc/dashbmw.jpg)
Do you not have any tunes or is it behind that panel?
No tunes. It all started with a Rabbit I had that came with a full factory radio delete. Ever since then I've been fascinated by the idea. It really doesn't bother me to not have tunes. Even in my cars that have CD players I find myself driving around with them turned off.
So where did you get the material to make the cover plate?
Material? :D
There's a BMW part number on the back of it. Factory radio delete plate. Oh yeah... no more OBC either.
I see, thought you made the plate yourself.
Item 3 here? (http://realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=65_0027&hg=65&fg=05)
Do you have the part umber for that? It doesn't look like it referenced in the link. I want to do the same thing. Do you have a part number for the A/C switch delete panel? Looks good!
Found both! Items 10 & 11
Looks like dealership time on Monday for me!
Does anyone know if they make the kick panels near the floorboard without the cutout grille area for the speakers?
http://realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=64_0097&hg=64&fg=20
It looks like all the kick panels had grilles :mad:
anyone got a part number for the OBC delete plate?
thanks
mike
The A/C blank panel is the same as the ones above the radio (the four switches: hazards, etc).
I finished it awhile back. Everything deleted. :D
(http://i62.photobucket.com/albums/h109/rfritzindy/DSC00312.jpg)
What models had that analog clock?
I don't know what models, I bought it on ebay. You can splice a plug from power mirrors to get power, the plus end is a perfect fit for the clock.
the M3 i think i got mine off ebay also, i spliced into the old clock plug so it still gets light and everything just like the factory clock. i think it only cost like $15 to, just type in "E30 clock"{ in ebay.
Anyways the radio delete looks clean!
It was a standard option on every European 318I-318IS-320I-320IS-325I-325IS. Only 316I did not have it, because there was a huge clock instead of tachometer (except 316I Bavaria model). M3 models did not have it. I suppose all european facelift models had it. I used to own a 1983 320I and it had a digital clock which i replaced with this analog one. It was a direct bolt-on job.
