DISCUSSION => Engine + Driveline => Topic started by: bryan@cedainc.net on October 17, 2010, 07:59:28 PM
PS pump is shot so I removed the belt. Steering is tight but manageable & preferable for autocrossing. I really don't need it & could stand to lose some weight (the car, not me). Should i remove entire PS system...pump, resevoir, plug hoses, etc? Any issues, problems deleting this system? Thanks
KY Colonel
I've removed the belt on mine too. No problems, unless you mind a little upper-body workout whilst parallel parking.
I made sure to drain the rack so I wasn't pushing fluid around. I'll get to pulling the rest of the P/S system one of these days.
There was a member with some nice alu blanking plate for the steering rack fitting. That'd be nice.
I removed everything including the the bits inside the rack and it seem to lighten up the steering effort as opposed to just removing the belt
http://www.flyinmiata.com/tech/depower.php?x=1
yep, remove it all. drain the rack and plug it to keep dirt/water out. You can lose like 15-20 lbs and with no fluid steering will be easier.
Peer pressure DEMANDS IT!!
