DISCUSSION => Electrical => Topic started by: Kacandpa on September 25, 2010, 11:08:38 PM
I've been reading this forum for ages now, thought this is the first time i've posted as it's actually the first time I haven't been able to find a thread with the problem that i'm having already discussed!
I replaced my starter motor about a month ago, happy to have my car starting on the first turn of the key again! I had no problems until the registration ran out and I figured it was a good time to prepare him to be painted! The car sat in my drive way for about 3 weeks, during which it was started and driven a few times but the other day when I went to move the car, it wasn't turning over. At the turn of the key it sounded like a freaking rattle gun, as if the gears weren't meshing correctly or the pinion gear wasn't engaging. The problem is intermittent as after two days I attempted to start it again and it started immediately. :confused: Are these symptoms consistent with a (hopefully) faulty solenoid? Or could I perhaps have a worn ring gear? I only hope that maybe somebody has had a similar problem to me as pulling the starter out again is going to be a huge pain in the butt!
Likely it's a bad solenoid, not throwing the pinion all the way against the flywheel ring gear. The pinion spins against a few ring gear teeth and sounds like that. I don't think any BMW starters are shimmed, so it wouldn't be a mis-alignment.
To be sure it isn't a few teeth stripped off the flywheel get a wrench on the crank bolt & turn the motor over a bit. 1/4 turn or so would do it. Or start it down a slope in neutral and pop the clutch into gear to bump the motor over. I'm with you on the starter...they're not easily accessible.
thank you for your input!! im going to change the solenoid over tomorrow!
