DISCUSSION => Engine + Driveline => Topic started by: spike318is on July 22, 2010, 08:21:59 PM
Title: loud tapping on cold start, not tensioner
Post by: spike318is on July 22, 2010, 08:21:59 PM
hi i have a 90 e30 318is, after reading many forums about this problem i bought and fitted a timing chain tensioner for the m44 because i heard this was a more reliable part and would solve the loud ticking on cold start but with no luck. am i gonna have to rebiuld the head?
Post by: colin86325 on July 22, 2010, 11:36:33 PM
You might just have some lazy lifters.  Pour about 1/2qt of ATF in the oil and run the car at moderate rates (that is, don't go above 6k) for a few hundred miles. Then change the oil.
If you still have noises after this, then you can test the lifters individually to see which need replacement.
Post by: spike318is on July 23, 2010, 09:05:51 AM
cheers colin, have a bottle of ATF in the trunk for my leaky powersteering pump, will put some in this evening and see how it goes. thanks again.
