DISCUSSION => General Topics => Topic started by: usaexec on July 22, 2010, 10:52:46 AM
Recently I have started to lose some coolant in my 1998 E36 Convertable. They is no leak, the radiator, water pump & all hoses are new.
What I am finding is after I stop a small amount of fluid is condensing out the overflow tube. Not much, but it adds up so I have to top off ever couple of days.
The temp gauge is working and read fine.
Any suggestions?
Fix it.
http://www.m42club.com/forums/showpost.php?p=25156&postcount=23
Shouldn't that system be closed? You have an external tank, correct?
I'm totally unfamiliar with your coolant set up, and without a model, I can't reference anything for you.
tjts link will be helpful if you have an integrated tank like my e30 does.
I'm pretty sure all E36 cars had the built in reservoir. The E30/M42 was the first car they used it on as far as I know.
I stand corrected.
Recently I have started to lose some coolant system or recovery tank (http://www.drivewire.com/part/cooling-system/coolant-recovery-tank/) in my 1998 E36 Convertable. They is no leak, the radiator, water pump & all hoses are new.
Any suggestions?
if you have a problem on your coolant overflow or tank, you could try checking your radiator cap. It is actually sealed and caps are junk. When you get to have a new one always push down hard, like screwing it in or you will have to broke.
