DISCUSSION => Electrical => Topic started by: Montanvs on July 06, 2010, 09:36:33 PM
Title: 1/2 instrument cluster back light out
Post by: Montanvs on July 06, 2010, 09:36:33 PM
Just wondering if anyone else has had an issue with the instrument cluster back lights?  Mine has half a side (right side) that does not go on......well sometimes it does.  Usually a tap on the dashboard lights it up fully.
It clearly is not the bulbs.  Loose connector?
Post by: jscribble on July 06, 2010, 09:44:31 PM
Same deal for me. I like feeling like the fonz though.
Post by: DesktopDave on July 07, 2010, 11:48:41 AM
The three main bulbs share a pair of strip contacts that run across the back of the dash plate.  The three larger sockets unscrew and will accept a replacement wedge bulb.  Replace all three while you're in there, it's a pretty tedious job...especially if you still have an airbag.
Post by: Montanvs on July 10, 2010, 08:04:27 PM
since the bulbs seem to still work is it possible that some sort of corrosion has made the strip contacts intermittent?  The bulbs clearly still work at this point.
I dont have an airbag steering wheel, so should be easier to replace.
Post by: jscribble on July 10, 2010, 08:23:49 PM
It's just a bit time consuming, and while you have it all apart, it would be a good time to replace these bulbs. It's a few bucks vs a few hours of work if one goes out a week after you clean up the sockets.
