DISCUSSION => Engine + Driveline => Topic started by: Rich Dixon 91is on June 24, 2010, 12:24:15 PM
Title: cat heat shield rusted away
Post by: Rich Dixon 91is on June 24, 2010, 12:24:15 PM
I have been using a stock cat with an aftermarket cat back exhaust with a magnaflow muffler. The heat shield on my cat converter has broken free because the weld spots look like they're completely rusted away. There's nothing left to weld, so I think I have to replace the factory cat. Any suggestions?
Post by: cristimm on June 25, 2010, 03:15:31 AM
Yes, remove the shield and you're done. I did this more than a year ago and there are no downsides (the car has a second heat shield above the cat).
Post by: Rich Dixon 91is on June 25, 2010, 04:33:45 PM
Quote from: cristimm;93893
Oh really? I started to snip it off to have a look, but I was afraid of going any further because the element in a cat obviously gets red hot and I don't want that on my kiester. I assumed a dead heat shield would be a new cat, but I thought of trying to shield it on the undercarriage side with something. If you deleted your shield and kept using the cat with no problem then I'll try it.
Post by: jscribble on June 25, 2010, 10:18:57 PM
Definitely try it. If there are no leaks, then there is probably not much of a reason to swap it out, especially if you are happy with the tone you get from yours.  Mine had a small hole (unlike the res and muffler - you could fit a baseball in either), and I guess I got lucky, as many don't like the sound a universal cat gives.
