DISCUSSION => Suspension => Topic started by: madman mike on June 21, 2010, 09:20:54 AM
Title: Steering Rack Differences
Post by: madman mike on June 21, 2010, 09:20:54 AM
I need to replace my steering rack..went to rebuild one, and upon installation and filling with fluid..it leaked like a siv!  I think I installed a seal in reverse..
Looking at rebuilt ones now..finding non-airbag ones a lot easier and cheaper than the airbag steering rack.
My question is ...what's the difference?  My car is a 91 318is, airbag model..I'm deleting the airbag..and I don't know how the rack does anything for the airbag anyhow...
What's the physical difference in the racks?  Anyone know?
thanks.
Mike
Post by: PumpItUp on June 21, 2010, 08:43:27 PM
i thought it was just the steering column that's different
anyway don't waste your money rebuilding. you can get a used e36/e46 rack for the same money,
 or european/aftermarket manual rack for a bit more
Post by: ///M3-18is on June 22, 2010, 09:56:58 PM
Does the e36/e46 M3 racks fit? Any mods required to get, M or non-M racks to fit?
Post by: max123 on July 30, 2010, 11:24:16 AM
Just a note on rebuilding - I thought I was up to the job - got the rebuild kit - even bought a cheap wrecker rack so that I wouldn't risk being stranded.  Anyway, taking the rack apart is a fiddly job that you really need precision tools to do correctly.  The problem is that by messing around with the rack on your garage floor or shop table you are going to inevitably hit, scratch or scuff the main rack piston - especially around the tie rods.  If your scratch it, the rack is toast and will leak.
What's the point - you spend $80 on a new seal kit and the rack leaks again?  I have had no luck with factory rebuilds either - my last one was good for 18 months and then gave up the ghost ($600 down the drain).  The reality is that the OEM rack is garbage.
Now I just run it old school - no power steering.
Anyway to get the e36 rack to fit you need spacers on the mounting point and you need to make a frankenstein u-joint for the steering column (part e30, part e36).  Zionsville sells it as a kit - http://www.zionsvilleautosport.com/store/screen/prod/store_code/6134/product_code/E30SRC.htm
Post by: romkasponka on July 30, 2010, 11:56:26 AM
e46 rack has better ratio.
