FAQ / REFERENCE => Member Profiles => Topic started by: manchuk on June 08, 2010, 12:11:31 PM
Title: manchuk
Post by: manchuk on June 08, 2010, 12:11:31 PM
supercharged m42 build 15psi:D
i am starting with the engine first before the car
heads plained .030
ported and polished
vac tefcoat main bearings
vac tefcoat rod bearings
arp rod studs
maxsil pistons
deves piston ring
cometics .120 head gasket
arp head studs torqued to 84lb
every gasket o ring and seal replaced every where possible
miller w.a.r chip (not purchased yet)
eaton m62
i should have started takeing pictures earlier in the build but here are a few
Title: manchuk
Post by: manchuk on June 09, 2010, 07:09:19 PM
head torqued to 84lb
Title: manchuk
Post by: manchuk on June 12, 2010, 04:28:16 PM
:confused:it wont let me upload pics
Title: manchuk
Post by: manchuk on June 12, 2010, 05:21:06 PM
head back on
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01245.jpg)
Title: manchuk
Post by: manchuk on June 12, 2010, 05:27:39 PM
timeing complete
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01257.jpg)
Title: manchuk
Post by: manchuk on June 12, 2010, 05:35:02 PM
valve cover
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01252.jpg)
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01253.jpg)
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01254.jpg)
(http://i770.photobucket.com/albums/xx346/manchuk/DSC012641.jpg)
Title: manchuk
Post by: manchuk on June 12, 2010, 05:42:53 PM
this is frank hes my freinds dad  from portugul  he is 82years old and the project would not be feesable without his knowledge(http://i770.photobucket.com/albums/xx346/manchuk/DSC01265.jpg)
Title: manchuk
Post by: manchuk on June 12, 2010, 05:46:48 PM
so far so good
(http://i770.photobucket.com/albums/xx346/manchuk/DSC012661.jpg)
Title: manchuk
Post by: jscribble on June 12, 2010, 09:35:15 PM
Looking good! I hope I get to do something similar... Working on buying a house to store my stuff, and a garage to LIVE in! I will be following this closely.
Title: manchuk
Post by: manchuk on June 13, 2010, 09:45:38 PM
exhuast mani
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01284.jpg)
Title: manchuk
Post by: manchuk on June 13, 2010, 09:51:02 PM
started vac lines with the mess under the intake delete (thanks to the guy who posted that 4 us on here, its ingenious)
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01283.jpg)
Title: manchuk
Post by: manchuk on June 13, 2010, 10:04:38 PM
eaton m62:) i was hopeing to put where the ac was but it will hit the motor mount so now we are going to move the alternator there and should have lots of room in that spot
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01278.jpg)
im haveing a couple of custom v belt pulleys turned down from cold role i would have liked to keep the electric clutch but couldnt find a serpentine kit in time b4 the build got to this point and i would have never got the psi i wanted out of it
Title: manchuk
Post by: manchuk on June 13, 2010, 10:11:49 PM
afm
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01281.jpg)
Title: manchuk
Post by: jscribble on June 17, 2010, 09:05:57 PM
Wow, this is looking great, manchuk! I like the attn to detail on the motor, brackets and covers. Looking really sharp! Is that intake boot oem & red tape? Where did you pick up the head studs?
Title: manchuk
Post by: manchuk on June 18, 2010, 12:13:19 PM
i got the head studs from top end performance along with the .120 head gaskets from cometics
and it is self fuseing silicon wrap on the intake boot, it makes a solid layer of silicone once it overlaps it self
Title: manchuk
Post by: jscribble on June 18, 2010, 08:05:23 PM
I like the wrap.  Keep the pics coming!
Title: manchuk
Post by: manchuk on June 19, 2010, 04:03:05 AM
just got the fenders  ill update later
Title: manchuk
Post by: dude8383 on June 21, 2010, 01:29:05 PM
Looks sick...I love motor builds :)
Title: manchuk
Post by: ///M3-18is on June 22, 2010, 12:49:43 AM
Quote from: manchuk;93695
Is the silicone wrap tape similiar to this?...http://www.rescuetape.com/?gclid=CPGFicr7sqICFSZHagodKngS6A
Title: manchuk
Post by: bazzi on June 22, 2010, 04:27:27 AM
Nice work men
Title: manchuk
Post by: manchuk on June 22, 2010, 11:08:18 AM
yah its the exact same stuff as rescue tape the more layers u put on the thicker it gets , i actulaly screwed one piece ip and had to cut it off, and when i did it actually fused together so good it was solid silicone and couldnt be pulled off. ,,,,,,, dont buy rescue tape brand. look on ebay for self fusing silicone and people have it on there cheaper and in different widths as well but it is still expensive, but it does an amazeing job (900psi)
i even fixed a small hole in my pressure washer line
Title: manchuk
Post by: 1991 E30 M42 on June 22, 2010, 07:18:31 PM
Everything looks great except for your cam gears which look pretty worn. Keep up the good work and keep posting pictures.
Title: manchuk
Post by: manchuk on June 23, 2010, 07:43:23 AM
yah in that pictures they do look a little worn, but they are not, its actually becuase i started cleaning them around the edges and then thought they are just going to be covered in oil again, so when i took the picture the flash reflected off the teeth becuase they were shiney
Title: manchuk
Post by: Hey-u on June 23, 2010, 01:22:42 PM
Looks good. Very interested in this build please keep the info coming.
Title: manchuk
Post by: manchuk on June 25, 2010, 10:50:39 PM
finished the mess under the intake delete today
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01297.jpg)
Title: manchuk
Post by: manchuk on June 25, 2010, 10:58:18 PM
took the super charger apart that i bought off ebay it is in amazeing good shape..
im going to replace the needle bearings anyway just becuase they are so cheap and its apart anyways
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01309.jpg)
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01308.jpg)
Title: manchuk
Post by: manchuk on June 25, 2010, 11:03:29 PM
built the exhuast flange for the supercharger and started to grind the welds to inspect for holes and cracks to make sure it is air tight
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01315.jpg)
Title: manchuk
Post by: YetiX on September 28, 2010, 02:08:16 PM
And . . .
Title: manchuk
Post by: manchuk on September 28, 2010, 03:35:03 PM
sorry for any delay guys bin super buisy with work havnt bin able to post any new pics becuase i havnt had time to work on it IN AWHILE. BUT THESE THINGS TAKE TIME AND MONEY and im just glad that iv been still workin as much as i have with the resession
Title: manchuk
Post by: manchuk on October 01, 2010, 02:57:30 PM
abandoning supercharger project goin turbo sorry for getting ur hopes up guys (TORBONETICS T3/T4 HYBRID)
Title: manchuk
Post by: romkasponka on October 01, 2010, 03:29:32 PM
Quote from: manchuk;97042
Good decision.
p.s. "mess under the intake delete" that way IMHO is better, better head cooling, X-flow....
(http://img201.imageshack.us/img201/9162/dsc01297x.th.jpg) (http://img201.imageshack.us/my.php?image=dsc01297x.jpg)
Title: manchuk
Post by: manchuk on October 13, 2010, 03:19:17 PM
-ordered m50 manifold to cut last to cylinders off ,it seems very logical for the price.$115
-garrett airesearch t3 .42/.48 AR  , i know its a little small but for 12psi and $150 i cant go wrong
-oil feed kit $40 (with psi reducer)
-oil drain parts $40 (fuck oil pan taps are expensive)
sold my supercharger for 450
so i bought all this and have a little bit left for trouble shooting
Title: manchuk
Post by: manchuk on October 13, 2010, 03:22:38 PM
thanks for the input romkasponka, i was actually going to use those 2 points for water cooling the turbo i was looking at but, after getting the deal that i did on the turbo without water cooling im going to switch it over to the x-flow set up
Title: manchuk
Post by: manchuk on October 13, 2010, 03:42:36 PM
my friend is going to portugal for the winter, where i had car stored and was being worked on..
so i decided to bring the girlfreind home so i can work on it
Title: manchuk
Post by: manchuk on October 13, 2010, 03:45:20 PM
raped the front end so i can put truck bed liner in the engine compartment
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01456.jpg)
it looks like the windshield is cracked but its just a reflection
Title: manchuk
Post by: manchuk on October 13, 2010, 03:47:22 PM
new fenders
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01460.jpg)
the old one wher rotten about a foot up from the rockers
Title: manchuk
Post by: manchuk on October 13, 2010, 03:51:35 PM
home made engine hoist
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01461.jpg)
it works good, i have 2 8" legs going thrue the floor joice's
put it all together for about $30 at princess auto (thats with the 1/2 ton come along)
(http://i770.photobucket.com/albums/xx346/manchuk/DSC01462.jpg)
Title: manchuk
Post by: manchuk on October 13, 2010, 03:54:54 PM
a picture of what my manifold should look like
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/manifold.jpg)
Title: manchuk
Post by: manchuk on October 13, 2010, 03:56:01 PM
the turbo i bought for $150(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/turbo.jpg)
Title: manchuk
Post by: manchuk on October 13, 2010, 03:57:51 PM
now all i need is to get a bit more cash and find the time to continue
Title: manchuk
Post by: mtle30 on October 15, 2010, 12:12:11 PM
Nice job! I hope someday I'll have the time and money to do this to my M42
Keep up the good work!
Title: manchuk
Post by: manchuk on October 15, 2010, 10:14:22 PM
well instead of waiting around for my turbo and manifold to come i decided to tinker with the shaved door kit i built, i got the driver side gutted and solonoid installed today(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01477.jpg)
Title: manchuk
Post by: manchuk on October 15, 2010, 10:16:11 PM
the popper work great and are instantanious!!!!!!
heres a pic of the interior releases(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01479.jpg)
Title: manchuk
Post by: manchuk on October 15, 2010, 10:20:37 PM
poor girl needs a good scrub on the inside
shes bin sitting for 5 years
Title: manchuk
Post by: manchuk on October 16, 2010, 09:01:46 PM
parts didnt show up again today so i decided to keep going on the cosmetics so i finished installing the remote kit for the shaved doors and while i had the kicks torn apart i switched the front speaker(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01480.jpg)
i was actually surprized that 6 1/2 fit in there without any cutting(http://i770.photobucket.com/albums/xx346/manchuk/bimmer the/DSC01482.jpg)
Title: manchuk
Post by: manchuk on October 16, 2010, 09:02:25 PM
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01482.jpg)
Title: manchuk
Post by: manchuk on October 16, 2010, 09:06:24 PM
the 3 way toer holds the kick plate cover out a bit but you cant even tell
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01489.jpg)
Title: manchuk
Post by: manchuk on October 16, 2010, 09:09:03 PM
got the new fenders on what a pain in my ass cutting and drilling and until they where nice
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01487.jpg)
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01486.jpg)
Title: manchuk
Post by: manchuk on October 16, 2010, 09:10:28 PM
welded som metal over the handle holes and started the bondo(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01485.jpg)
Title: manchuk
Post by: manchuk on October 20, 2010, 08:40:02 PM
finished the spray on liner in the engine compartment(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01493.jpg)
i was actually surprized how wel it workedhttp://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01492.jpg (http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01492.jpg)
Title: manchuk
Post by: manchuk on October 20, 2010, 08:41:10 PM
Title: manchuk
Post by: manchuk on October 20, 2010, 08:43:52 PM
turbo manifold showed up in the mail today
(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01494.jpg)
Title: manchuk
Post by: manchuk on October 20, 2010, 08:51:22 PM
so of course the first thing i did was hack it up and weld a end on it(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01498.jpg)
Title: manchuk
Post by: manchuk on October 20, 2010, 08:53:33 PM
an now im ready for the moter to go in(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01499.jpg)
Title: manchuk
Post by: manchuk on October 22, 2010, 11:13:17 AM
ok my fellow m42 junkies look what i did last night(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01503.jpg)
Title: manchuk
Post by: e30boarder on October 22, 2010, 11:35:18 AM
thats beautiful dude
Title: manchuk
Post by: manchuk on October 22, 2010, 06:30:09 PM
well i have been waiting for my turbo, oil feed line, and drain kit for about 2 weeks now , and just after i got home today , the ups guy pulled up, it was so exciteing!!!, well after jumping for joy, the fucking asshole delivered a package to my neighbour
Title: manchuk
Post by: manchuk on October 22, 2010, 06:57:49 PM
so this is what i did instead
i cut open the whole accessory harness becuase the last time i drove the car was 5 years ago and i rember vagly that alot of stuff was starting not to work, i found 6 wires that where shorting and 2 that where completes cbroken in half(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01512.jpg) as you can see i missed a spot with the bed liner(the red spots)(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01513.jpg)
Title: manchuk
Post by: manchuk on October 22, 2010, 06:59:53 PM
i need to grind out the tabs that held the abs unit in b4 i can do the touch ups i totaly forgot about them until i was spraying it on, that where i have to put the windshield washer container
Title: manchuk
Post by: manchuk on October 22, 2010, 07:05:09 PM
and then i also relocated the afm and filter and extended the afm wires(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01516.jpg)(http://i770.photobucket.com/albums/xx346/manchuk/bimmer/DSC01509.jpg) theres a little bit of rust ther, but ill get that in the spring ,when i can get it up on the hoist and respray all of the underbodey
Title: manchuk
Post by: manchuk on October 27, 2010, 07:30:45 PM
turbo came today cleaned it up a bit it spins freely and has no shaft play lets hopethe seals are good(http://i770.photobucket.com/albums/xx346/manchuk/DSC01527.jpg)
Title: manchuk
Post by: manchuk on October 28, 2010, 10:06:52 PM
well went to go start it for the first time today and the starter was siezed , i was actually able to take it apart and rebuild it on the spot, finally at 10.48 the car turned over and started instantly, i mean fucking instantly, i just wanted to here it after the com[plete rebuild. thanks frank you did a fucking awsome job giveing me a hand
Title: manchuk
Post by: unt0uchable on November 05, 2010, 11:47:07 PM
Seems like a fairly inexpensive setup. What kind of engine management are you going to run?
Title: manchuk
Post by: manchuk on November 07, 2010, 04:30:02 PM
well havn't been here for awhile boys but its mother fuckin turbo time biytches(http://i770.photobucket.com/albums/xx346/manchuk/DSC01543.jpg)
Title: manchuk
Post by: manchuk on November 07, 2010, 04:34:05 PM
dont worry im going cop kit but i got it running off wires for now
i still cant believe i bought the garrett ta0301 turbo for 150 and it runs as good as it does,
but anyways here it is
Title: manchuk
Post by: manchuk on November 07, 2010, 04:40:17 PM
no im  not running a independant management!!!!!!!!!!!!!
bears bmw, bmw connect, midnight tuneing is going to hook me up with a custom ecu (#175) chip to get me running on #42 injectors to drive the car down to ottawa and then custom tune for 15psi from there , apparently that mother fucker knows his shit so he has advised me when im ready we will doo it , check out his vids on you tube
Title: manchuk
Post by: manchuk on June 18, 2011, 11:01:19 PM
hey guys got my self into some trouble went too jail for 8 months and havnt had a chance to work on my bitch anyways im out now and will update the build hopefully
Title: manchuk
Post by: e30boarder on June 20, 2011, 09:32:52 AM
damn thats harsh. hope everything works out man. cant wait to see more pics of the car
Title: manchuk
Post by: manchuk on June 22, 2011, 11:49:08 AM
it seems like a not so expensive build but i completly rebuilt the hole moter plus i added vac tefcoat bearing all around arp head studs and lowered the compression and used deves rings so its a little more than just makeing a junkyard turbo kit
yes i used a used turbo and did some fabricateing myself but i made the moter strong enough to jam 20psi down its throat if i want to in the future but for now ill stay at the 12psi that this turbo can handle so no it is not completly inexpensive becuase i prepared the moter for future hp
Title: manchuk
Post by: manchuk on August 07, 2011, 09:36:46 PM
hey guys havnt done much too her still but noticed the turbo was leaking a bit of oil so i completly rebuilt it and changed the main intake boot ill post some pics shortly
Title: manchuk
Post by: ZaNDeR on September 23, 2011, 10:36:10 PM
Looks awesome! Great job
