PAPER OR PLASTIC => WTB/WTT => Topic started by: Crazytek on May 15, 2010, 01:16:58 PM
Title: WTB e36 m42 Cylinder Head
Post by: Crazytek on May 15, 2010, 01:16:58 PM
Looking for a e36 m42 Cylinder head for a 1994 318i.  I believe the Cast # is 464
Post by: Alwaysinabimmer on May 17, 2010, 09:41:35 PM
Quote from: Crazytek;92473
I have one from a 91, will that work?
Title: Head
Post by: Crazytek on May 19, 2010, 09:50:07 AM
Thanks for the offer.  I'm in California so not really local but I have no problem paying for shipping to get it here.  Not sure if it will fit.  I know the cast # on the side of my head is #1721464.  Does yours have the same number?
Thanks,
Kyle
Post by: ///digitalme on May 19, 2010, 05:57:31 PM
i also have one for a 91 318is it does have a little damage...and 4 bent valves...but im asking 40 for it....im in cali
Post by: ///digitalme on May 19, 2010, 06:03:05 PM
also im pretty sure the 91 head will fit fine, im sure they use the same head up to 94 i believe...they might use different cams but should fit fine...also you can check
realoem.com and check the differences...
Post by: Romrog318is on May 19, 2010, 06:07:41 PM
^^ motors are the same just different pullys
Post by: monko141 on May 19, 2010, 08:21:29 PM
Post 92' m42 heads have different exhaust valves and use a single valve spring.
