DISCUSSION => Engine + Driveline => Topic started by: yoyon on May 13, 2010, 09:39:20 AM
Title: noisy lifter+rocker after install dbilas itb+cam
Post by: yoyon on May 13, 2010, 09:39:20 AM
hello,
my engine is m42b18 e30 standard. recently i'm installing new dbilas ITB and camshaft+ valve spring.
once finish all item installed, the engine noise rattling from rocker+lifter is so loud.
i wonder, is it HVA failure? should i use solid lifter?
any suggestion is appreciated
thanks®ards,
Post by: flyinglizard on May 13, 2010, 09:00:39 PM
Run it at 1700- 1800 for at least five minutes. It goes away
Post by: BlueBMW on May 13, 2010, 09:32:50 PM
Probably bad ITBs... you should just give them to me for free!  J/K yeah, they're hydraulic lifters and need to bleed out so you'll have some bad rattle for a few minutes.
Post by: carlos318is on May 14, 2010, 04:52:56 PM
I have had the same problem for years and never caused any damage
Post by: jmsra on May 24, 2010, 10:31:30 PM
So if i just replaced a cracked head and checked all the timing components and put it all back together i would get that diesel noise until the lifters were bled out?
Post by: yoyon on September 04, 2010, 08:54:34 PM
found out that hvas are bad condition, replace them with custom solid lifter
