FAQ / REFERENCE => Member Profiles => Topic started by: NisseJärnet on April 25, 2010, 07:01:20 AM
Hi everyone!
Im pretty new here, living in sweden so my english is not that good :rolleyes:
This is a great forum! Im pretty new to the M42, but i know the M20 inside out :)
I have a E30 M20 turbo putting out pretty good power but recently started building a E30 M42 turbo with a friend, and then when we already was in the garage i picked up a complete M42 from a E36 and a complete but taken apart E30 M42 engine and started swaping the E36 motor in my winter-drifting car, 318i M40.
So we have our hands full at th moment, the 318is turbo is gonna be dynoed in a few weeks and has some small work left, IC piping, exhaust, oil feed to turbo and some other small things. More info on this car soon!
I started the 318 M42 swap yesterday efter some electrical work and everything seems to be working, so now its time to build exhaust and fix the drive shaft and then test it on the road :)
I used a -93 E36 M42 engine complete with ECU, harness, gearbox with clutch cylinder etc, M40 mounts and brackets. My rive shaft seems to be like 1cm too long though so ill have to to something about that, ill be back on that one.
The E30 M20 6 speed turbo is pretty much turn key from last year, just made some small mods and gonna check it out in the dyno soon as well.
Will post some pics and videos soon! If anyone wants to see :)
Finished the E36 M42 swap yesterday, works lika a charm! Much more fun to drive it now than before with the M40 hehe.
Yes
Yes
+1, also interested.
Great work man! Some info on the setup would be much apreciated. Which turbo did you use? What is the size of the IC, pipes size, exhaust size, soft?
Looking forward to the progress of your work.
The 318is M42 specs:
Mitsubishi EVO8 turbo
Home made puls split manifold
630cc injectors
MS ECU with stock coils
600x300x102mm intercooler
Bosch BOV
3" intercooler pipes
3" exhaust
ARP head bolts
O-ring block
M50 non vanos rods for lower comp
M20 flywheel with sinter clutch and 325 E30 pressure plate
Right know im building the ic pipes, exhaust and oil feed to the turbo :)
Videos of the M20 turbo can be found here http://www.youtube.com/nissejarnet
Videos of the is turbo will come as soon its finished :)
is turbo pics:
(http://forumbilder.se/images/118201013234A768d.jpg) (http://forumbilder.se)
Cleaned stock pistons:
(http://forumbilder.se/images/6e8201013321A80ea.jpg) (http://forumbilder.se)
Didnt bother to paint the block:p
(http://forumbilder.se/images/c98201013431A1036.jpg) (http://forumbilder.se)
E30 M20 turbo:
(http://forumbilder.se/images/658201013835Ab654.jpg) (http://forumbilder.se)
A little street racing:
(http://forumbilder.se/images/cb8201014009A9be3.jpg) (http://forumbilder.se)
(http://forumbilder.se/images/658201014107Aab70.jpg) (http://forumbilder.se)
E30 vs. American muscle
(http://forumbilder.se/images/b58201014233A2cd2.jpg) (http://forumbilder.se)
(http://forumbilder.se/images/8d8201014600Ad731.jpg) (http://forumbilder.se)
3:d place for me (upper left)
(http://forumbilder.se/images/868201014307A258c.jpg) (http://forumbilder.se)
E30 with M42 E36 engine
(http://forumbilder.se/images/598201014844A9524.jpg) (http://forumbilder.se)
Ill try to get some more engine pics of the is turbo tomorrow!
More E30 is turbo pics!
Nice rebuild head
(http://forumbilder.se/images/768201051902P666a.jpg) (http://forumbilder.se)
Clean and ready to go inside the engine!
(http://forumbilder.se/images/138201052124P0241.jpg) (http://forumbilder.se)
Airpump with weird exhaust housing
(http://forumbilder.se/images/b98201052559Pd101.jpg) (http://forumbilder.se)
Ready for the head!
(http://forumbilder.se/images/b48201052703Pa687.jpg) (http://forumbilder.se)
More pics soon :)
Home made manifold + turbo.
To bad i didnt TIG weld the manifold, but hey that doesnt make the car faster :)
(http://forumbilder.se/images/57201011051AMc7e9.jpg) (http://forumbilder.se)
Had to cut a mounting thingie off the compressor housing to clear the manifold, tight fit =P
(http://forumbilder.se/images/2e201011227AMe5fb.jpg) (http://forumbilder.se)
Wow bottom mount! You don't see that too often. Can we see some pics from the bottom?
Can take some pictures tomorrow :)
A short test movie featuring the E30 with E36 M42 engine :) 40-160km/h starting in 2nd.
http://www.youtube.com/watch?v=EKYbGeekC4M
I saw a white m20 turbo in action.... :)
It goes like the devil from hell... ;)
http://www.youtube.com/watch?v=LWEW0UL8ako&feature=channel
http://www.youtube.com/watch?v=BRDiULRvf0E
Wuhuu there i am :D
One more vs the V10 E30 http://www.youtube.com/watch?v=3FSzFesgDLg&feature=related
I need better tires:rolleyes:
You do not need anything, you have everything ... ;)
My friend drive similar turbo conversion, car is going great and the sound is amazing...
Car in the middle..., this is some practis for king of europe last week!!!
http://www.youtube.com/watch?v=JLNwvSRc0CM
http://www.youtube.com/watch?v=LVsXhMThsOI&NR=1
That V10 E30 is really something!!!!
I love the fact that you posted the E30 vs the Viper and then the turbo E30 vs E30 V10...you get a pretty good idea of just how quick the V10 E30 is!!
Dynoed the is turbo yesterday, 280hp :) I wanted more ouf of it but we had some problems with the MS at higer rpms, trigger errors i think so ill get back to that.
But i works really great below 6000rpm or so! Pretty fun :)
http://www.youtube.com/watch?v=I-ln2rVvzdE
Fine tuned my M20 turbo at the same time and the old 2 valve is now putting out 770hp :D
Could you post the dyno sheet, please?
Nice work!
With the M20, which 6-speed tranny did you use?
We had 240whp (should be around 280hp) but i think that sheet is in tha garage and im not home at the moment, but i had a picture on the 237whp run :)
(http://forumbilder.se/images/c55201030526Pdc75.jpg) (http://forumbilder.se)
I use the E36 M3 3.2 euro gearbox in the M20 turbo.
Good figures! I have 220whp/260hp using haltech e6x and completely stock engine.:D
Nice! :) I want 300whp atleast with this setup! New turbo and dp + check the cams should do the trick!
Oh yeah?!??! Well I have dyno proven 115 whp! So there! :D Your cars are an inspiration! One of these days..... turbo mmmmm... My co-workers were very impressed by both the M20 turbo and the e30 V10 videos. All great stuff.
The is turbo kit will be sold in a couple month, i have to get a bigger turbo =D
What turbo do you have now and what turbo do you want? In what rpm range do you want boost?
I have a T3/T4@0.6bar and I have boost in the upper range (2nd gear from 4500, 3rd from 4000, etc.). Redline is 6800rpm.
I have a Mitsubishi EVO8 turbo, dont know what turbo im gonna buy..it depends on if i replace the pistons and rods or not :)
I fixed the 6000rpm issue today, so now it goes all the way to 7000 rpm :)
WOW! How on earth did you manage that? How hard was it to integrate the haltech? Completely stock?!?!?!?!
With very good fine tuning and lots of patience. :)
It was a bit tricky until I managed to get wiring done. After that a friend did the proper maps.
Now I'm runing 0.6bar / 0.87 PSI. I think I can go 0.8bar / 11.6 PSI. :D
Sorry for the thread high jack. :)
That's really solid. Nice work Vladi. Any updates Nisse?
We put the M42 turbo engine in a diffrent car a month ago or so, it pretty much belongs to a friend now hehe :)
Short vid: http://www.youtube.com/watch?v=xIYhoPdvGKo
crazy swedes :p
i want it! :D
The complete engine is up for sale with the MS ECU, ignition, turbo etc just put in yor car and drive :)
My friend owns the 318is turbo and we went to a event where he raced a couple cars, this Porsche 911 for example:
http://www.youtube.com/watch?v=4f4VmOiLjqQ
M42 turbo engine sold a couple weeks ago :) M50 turbo on its way into that car...
The E30 with E36 M42 is going strong on the snow now! Works like a charm :) I swaped the 168 4.10 diff for a 188 3.73, stronger and works a little better with 1:1 on 5th gear, 200km/h @ revlimiter on 5th gear ~6800rpm. Good enough on the snow :)
can I ask for how much it was sold engine+turbo+ms?
Shure ~1600 EUR or 2100 USD. (without the clutch/flywheel/starter, radiator, intercooler and gauges)
Nice, thank you for the answer!
good luck with the six cyl, want BIG power? :D
Yes, big power is nice :) Im building a M50 to go in the M20 powered E30 as well :D
The turbo and manifold from the M42 turbo is up for sale by the new owner btw, he wants a bigger turbo :cool:
kan de funka o byta fläns på grenröret til t3 och använda nånn annan turbo? pris i sek?
