DISCUSSION => General Topics => Topic started by: DesertEagle on April 07, 2010, 07:41:56 PM
Hey All,
Has anyone ever had difficulty installing the rear brake sensor. I'm talking about just pushing the sensor into the pad cutout. I cracked one sensor. The second one sticks when the springs/clasps are fully depressed. The pads are Textar and the car is a 1991 318is. Is there something I'm missing or is there a trick to it?
Sincerely,
Churning in my own anger...
I removed the entire pad wear harness and took the light out of the cluster, problem solved
you're not too fond of the stock setup, huh?
i dont like anything stock
I had the opposite problem, on my hawk hps pads the sensor won't clip in tightly, it's loose and just falls out! Should I glue it?
