PAPER OR PLASTIC => For Sale => Topic started by: ///M3Mike on March 11, 2010, 09:32:55 AM
New house, must clean out the spare parts bin. Prices do not include shipping.
(http://i76.photobucket.com/albums/j32/g8rav8r/forsale/photo3.jpg)
-Stock 318is clutch fan and shroud. Works great, I just don't need it, I installed a Volvo 960 electric fan. $25
-318is electric A/C condenser fan (top left in picture). Not sure if this is stock, as others I've seen are 5-blade with flat blades. So this may have been replaced by the original owner. Just like above, it works fine, I just don't need it after installed a Volvo e-fan. $20
-Stock Volvo 960 electric 2-speed fan and shroud. Pulled from Pull-A-Part. I always buy 2 when I get something electric at P-A-P. Turns out both worked fine and I only need 1. It wires up directly to the E30 A/C condenser fan wiring, but I pulled some of the Volvo wiring and the relay if you want that too. Moves enough air that you can use 1 of these in place of the clutch fan AND the A/C condenser fan. It really cleans up the engine bay and makes belts and hoses a lot easier to get to. $25
-Almost new 318is/1.9 Z3 radiator expansion tank. I thought my old one was leaking so I replaced it about 3 weeks ago. Then while bleeding the radiator, I cracked the bleed screw housing so I needed a new radiator which came with a new expansion tank. This one has probably been used for 350 miles. $35 (I will clean it up before packaging)
-Euro E30 driver's side taillight bulb housing. Basically, if you want a rear fog light, get this. $20
-Stock E30 taillight bulb housings. US-spec, no rear fog. $20
(http://i76.photobucket.com/albums/j32/g8rav8r/forsale/photo-1.jpg)
BRAND NEW IN BOX E30 M3 offset control arm bushings. Never used. I accidentally ordered 2. I forget where I ordered them from and don't want to bother with shipping them back anyway. $30
(http://i76.photobucket.com/albums/j32/g8rav8r/forsale/DSC01633.jpg)BRAND NEW IN BOX E30 M3 rear brake spring kit. Same as above....thought I needed 2, only needed one. Never used. $30
How much for shipping on the Volvo fan to 22923 (Va)?
Better yet, if you're coming to the Rolex at VIR next month and bring it I'll pick it up there (I'll send you $30 Paypal now).
