DISCUSSION => Engine management => Topic started by: electrofelix on February 19, 2010, 07:35:13 PM
Title: Vacuum tests
Post by: electrofelix on February 19, 2010, 07:35:13 PM
I thought that the bentley manual would have some details on what measurements you should get when testing the various vacuum lines on the car, but I can't seem to find any.
Anyone know what values I should be seeing, plan to test all the various lines tomorrow, so it would be useful to know what the specifications should be.
Title: Vacuum tests
Post by: fiftytakedowns on May 25, 2010, 12:36:53 AM
bump?
Title: Vacuum tests
Post by: Hybrid775 on May 27, 2010, 10:08:18 PM
Testing vacuum? I would just visually inspect the hose and replace the broken ones necessary.
Title: Vacuum tests
Post by: DesertEagle on June 07, 2010, 06:56:05 PM
The manual that came with my mightyvac hand vacuum pump went into a lot of detail on how to interpret vacuum readings/fluctuations.  I also found info in the Bentley e36
Title: Vacuum tests
Post by: fiftytakedowns on February 10, 2011, 02:44:35 AM
Quote from: DesertEagle;93343
care to explain?
