DISCUSSION => Engine management => Topic started by: 318idol on February 15, 2010, 01:19:32 PM
Has anyone put together chip install how-to article? I know where the DME is, but not sure how to remove it. There's a plastic cover over it. Tips?
I have a new MarkD chip. Eager to try it out.
Also, should I get a grounding strap to work in the innards? Thanks, Gary
http://www.pelicanparts.com/bmw/techarticles/JF-Tech/BMW_E30_3_Series_performance_chip_install.htm
Thanks...I saw that...but no photos. I'm sure I can figure it out. Is the grounding strap necessary? Or are there other ways to prevent static electricity from being an issue?
It's like working on a home computer ,when you sit down or work on it ground yourself to something before you work on it. avoid things that cause static electricity like wool clothes or a rug .Just touch something metal before you start to work on it so you discharge yourself.
good luck
more reading http://www.e30tech.com/forum/showthread.php?t=43659&highlight=replacing+chip
There's a pic of the chip installed in this thread......scroll down
http://www.m42club.com/forums/showthread.php?p=74529
http://www.m42club.com/forums/showthread.php?t=10635
