DISCUSSION => Swaps, Turbos, Buildups => Topic started by: Stryker on January 28, 2010, 05:31:36 AM
Hi im fitting a t25 turbo to my e30 is and want to know what would be a good ecu to use? Also need to know if i need to upgrade my fuel pump spark plugs etc?
I would recommend either a full standalone (any would really do, just depends who can tune what) or a custom burnt chip for the standard ecu. You will need larger injectors and a slight fuel pump upgrade is preferrable. All depends how much boost your going to run really.
The spark plugs will need to be a step or two cooler also.
"tglaze" on the forums sell a Plug and Play MegaSquirt setup, this would involve the least work setup wise, but you would need to tune it yourself or find someone who can. There are a few people who could help you out with base maps for the MS setup though.
Your in the right spot. Have a poke around the build threads and see what the rest of us are doing :)
Miller performance chips makes a W.A.R. chip for the ecu on the e30 and e36. According to their applications guide if you have an E30 and the last three digits of the Bosch ecu are 175 they make one. If you have an E36 and the last three digits of your Bosch ecu are 282, they make one. So if you fit the descriptions, you should probably get one. they sell for about $350 and they are programable and you can use a couple of saved maps that you make from your pc.
I was thinking of running around 10psi of boost until i can save up enough money to buy pistons. What make of plug do you use as i cant find anyone Over here that can supply cooler plugs? also what make pump would you reccomend? Thanks for help so far.
just go to your local parts shop. they should be able to look in any brand of spark plug book (it really comes down to preference...i have none) find the M42 plug and find something suitably cooler.
10psi is about as much as most people seem to run before stepping up their game and spending money on the motor.
Most people go for the walbro pump as it is in tank and can be made to sit right in the e30 fuel pump cradle. I will be using the standard pump to fill a surge tank and then running a bosch 044 external.
Well i have arp rod bolts and head studs and a cometic head gasket. Im also wondering if e36 m3 injectors have a better flow rate than the standard is ones?
I have fine luck with NGK plugs.
http://www.ngk.com/default.asp?KID=76&gclid=CPrd-7nCy58CFRciagodRmYJ1A
Note this is a NGK distributor not NGK's web page. Lots of good information.
Dave
Dave
Thanks that is very helpful.
I'll be running megasquirt on mine for what that's worth. Seems suitably adaptable and I want to learn about EMS anyway.
The WAR chip is nice, but you can't tune it on the fly, which makes it a real pain.
Ok who is supplying the megasquirt?
What would be good injectors to use?
The Mustang Green top injectors on ebay (42lbers) are affordable and should cope with anything you throw at them. But some 32lbs might do the job.
"tglaze" on this forum was making PnP megsquirt kits.
:confused:
Ok thanks. Where do you pick the oil feed up from? And where do ye run the return to?:confused:
A tee piece where the oil pressure switch goes for the turbo feed and you need to modify the sump or timing case for a turbo drain. Remember to keep it above the oil level (timing case is best for this).
We've got a fitting that should work as well. We use it for mounting the oil pressure and oil temp switches and it fits into the oil filter housing. I'll try and get a picture up when I get home.
I have my oil filter relocated with a remote oil head. Thanks anyway.
Ok Thanks. Have you any experience on the engine running too much oil pressure? Because mine has blown the seals in the turbo.:confused:
What sort of bearings does the turbo have? Plain bushes or ball bearings? Ball Bearings need a very small restrictor (to limit the flow) whereas plain bush turbos will most likely not need a restrictor (but some do, just bigger than the ball bearing one).
Specifically I would ask the turbo supplier/manufacturer what size restrictor they recommend.
I have a Garrett Ball Bearing turbo and bought the proper sized restrictor Banjo bolt off ebay for the turbo feed. There may be something similar available for your specific turbo.
My turbo has plain bushings but im goin getting a ball bearing one now. Ok thanks ill look that up and see what i find out.
Who Makes a turbo , (garret,) exhaust manifold for the M42.? I have a pile of Merkur turbos left over form my prior life. TIA. MM
666 fab makes some nice ones. http://store.666fabrication.com/m42-tubular-turbo-manifold-e30-fit.html. bunta here on the forum had a good&tite m42 top mount for sale. i think his is flanged for a holset hx35.
We bought the original 666 Fab manifold for the E30 M42. 2 years later I suspect that we've run it harder than anyone else has.
Rob, what turbo are you running and current boost level?
You can find more info on our car in a few spots:
http://www.m42club.com/forums/showthread.php?t=9663
and
http://www.cardomain.com/ride/2980038
We've run multiple boost levels and are currently running 16psi+
