DISCUSSION => Engine + Driveline => Topic started by: ClubSport on August 14, 2006, 06:31:10 PM
What is the impedance of our injectors? High/Low?
Does anyone know the stock flow rate?
Thanks!
16 Ohm. High.
Stock the rate is 20.5 lb/hr.
What are you looking at doing? Sounds like either a stand-alone or bigger injectors for someone....
Hi, and thanks. I'm going to be using a PCIII and Shawn Fogg's writeup here http://ackthud.com/shawnfogg/fuelupgrade.htm to get some 36 lb/hr injectors running on my ti. Going to put on a 9psi pulley and see where that gets me.
