DISCUSSION => Engine + Driveline => Topic started by: 92BMW318is on December 20, 2009, 04:39:21 PM
Title: Coils, spark wires correct seqence :)
Post by: 92BMW318is on December 20, 2009, 04:39:21 PM
sorry guys to repost this, the other thread was getting messy as hell well i found the cylinder firing sequence and this is that fixed my problem with crossing spark wires
      here is a illistarted diagram by me, haha it does its purpose
Right!! :)
(http://img12.imageshack.us/img12/9068/blalalallalalalalllaa1.png)
(http://img687.imageshack.us/img687/7687/wiresz.jpg)
All BELOW ARE Wrong
(http://img109.imageshack.us/img109/7863/bmwr.gif)
(http://img130.imageshack.us/img130/7560/63717158.png)
Post by: ak96ss on December 20, 2009, 06:39:14 PM
OK, so did this fix your problem?
And FYI, the cylinders are number 1 through 4 from front to rear, so the coils would have the non-sequential numbering, not the cylinders.
Post by: tjts1 on December 20, 2009, 07:49:07 PM
Quote from: ak96ss;83320
+1 on that.
I have much shorter Volvo wires which you can actually follow from coil to plug.
(http://farm4.static.flickr.com/3133/2395970087_97844724b6_o.jpg)
Post by: 92BMW318is on December 20, 2009, 08:32:24 PM
the picture is still right tho
i was going by piston firing
Post by: 92BMW318is on December 21, 2009, 10:44:10 PM
okay guys fixed it sorry about that
Post by: dvmotorsports on December 21, 2009, 11:25:26 PM
Quote from: 92BMW318is;83314
All BELOW ARE Wrong
(http://img.photobucket.com/albums/v260/dvmotorsports/wires.jpg)
Broheim, this is the same thing as in the picture. I assure you it's not wrong. Just rotated 45 degrees.
Post by: fiftytakedowns on December 21, 2009, 11:37:15 PM
i dont understand, The wrong diagrams seem right to me.
Post by: 92BMW318is on December 22, 2009, 06:04:06 AM
Quote from: dvmotorsports;83388
what model is this for?
Post by: dvmotorsports on December 22, 2009, 11:10:28 AM
318 of course
Post by: dwtaylorpdx on December 22, 2009, 12:00:07 PM
Wonder if someone installed the coil packs in his car in a different order and just moved the coil input wires back at some point? LOL That would be evil....
Dave
Post by: 92BMW318is on December 22, 2009, 03:23:48 PM
(http://img198.imageshack.us/img198/9417/63951749.png)
this is what my coils look like, along with spark plugs, i dont understand why mine is diffrent
Post by: DesktopDave on December 22, 2009, 04:07:22 PM
Yup, they are different.  You'll have to chase those wires back to the DME.  Won't take you long.
Post by: dvmotorsports on December 22, 2009, 08:25:31 PM
Just get the pinout numbers and check resistance from the DME harness to the coil harness. For example when you plug into pin #25 and you find the resistance on the other end, that will be cyl #1. Then move that to position number one as I showed in the diagram. You will also need to go to the boneyard and get the bracket to mount the coils correctly.
Post by: dwtaylorpdx on December 22, 2009, 10:36:49 PM
Or convert to coil on plug.
Dave
Post by: tjts1 on December 23, 2009, 01:23:49 AM
Why are there zip ties on your spark plug wires?
Post by: 92BMW318is on December 23, 2009, 03:47:32 AM
Quote from: tjts1;83460
they are for number coordination.... well they were until i fixed the problem by switching switching 2 of them around
Quote from: dvmotorsports;83435
but whats funny is that those coils come with a cover that fits over them perfectly, its like a hard plastic shell, in the shell there is a bmw logo?
i dont know why they would make my coil pack rearanged diffrently, maybe they did this on 92, or just on 318is's, ha or maybe its from a diff bmw,
ill post back with pics on the coil cover
WARNING: Turn down you volume on your computer before watching this video, its really loud....
http://www.youtube.com/watch?v=Kqay5rQJCf4
whats this noise sounds like to me that one of the barrings on the water pump or somthing else is going out. you tell me
also once i rev the engine up above 2.5 rpms it goes away
Post by: dvmotorsports on December 23, 2009, 10:37:52 AM
They didn't make yours different. One of the previous owners did that. And the parts you are looking at are correct. The have just been remounted to a different spot and the plastic cover has been removed. The reason for that is the plastic cover is molded to fit the coils when they are mounted correctly in the shape of a square as shown in my diagram. It will not work when they are inline and out of place as yours are.
Post by: dvmotorsports on December 23, 2009, 10:39:16 AM
Should look like this
(http://www.e30zone.net/e30zonewiki/images/9/94/M42B18_Engine.jpg)
Post by: BimwadM42 on December 23, 2009, 03:46:29 PM
Quote from: dvmotorsports;83487
The OP has an E36, which has the coils arranged differently than the E30 in this photo.
As pictured in the OP's photo, the coils are correct, but the wires, if stock, could be arranged in a much tidier manner.
From '94 on, BMW refined the coil setup even further, with a single input wire from the engine harness, and a smaller, integrated coil pack containing all four coils.
Post by: 92BMW318is on December 23, 2009, 03:46:35 PM
did you ever watch that you tube video i posted? there is a url on my last post, please watch, i wanna know whats makeing that noise
(http://static.bmwfans.info/images/epc/MTUwMV9w.png)
English site
http://www.realoem.com/bmw/showparts.do?model=BE53&mospid=47480&btnr=12_0426&hg=12&fg=05&hl=6
heres the part its on a German site tho
http://de.bmwfans.info/parts/catalog/E36/Coupe/USA/318is-M42/LHD/A/1992/march/browse/engine_electrical_system/ignition_coil/
(http://img36.imageshack.us/img36/4299/93502018.png)
(http://img706.imageshack.us/img706/9488/93043264.png)
(http://img69.imageshack.us/img69/5906/20646201.png)
(http://img69.imageshack.us/img69/8636/fee.png)
(http://img8.imageshack.us/img8/189/75813322.png)
your intire engine setup is diffrent from mine,
my batttery is in the trunk and seems like  have more room in the engine compartment plus your hood opens backwards
you have a diffrent intake too
Post by: 92BMW318is on December 23, 2009, 05:30:14 PM
bump attackkkkkk
